Help.. I have a 2012 Cub Cadet LTX 1046 with a Kohler Courage 22hp engine. Is there an easy way to remove the shroud from this engine? After removing all screws and the shroud was free, the genius CC design of the fuel tank bump out right above the shroud prevents it from being lifted off of the engine. I tried uploading a picture several times with no success. Thanks
