Mower deck Cub Cadet LTX 1040 Mower Deck Belt to loose, how to adjust tension
Pirateship18m
  • / Cub Cadet LTX 1040 Mower Deck Belt to loose, how to adjust tension
I just bought a used LTX 1040 (2012). The guy said he put on a new belt. When I got home and started cutting the front yard the belt smoked and I found out it was put on backwards. I bought a new belt at the Cub Cadet dealer and put it on. It is a manual lever to engage the blades. The belt is loose when the lever is fully engaged. How do I adjust the tension on the belt to take out the excessive play? I know I have to leave some play in the belt so when the blades are disengaged the belt will slip on the drive (motor) pulley. Thankyou
There is a model number under the seat, would you please post it?
Pirateship18m
The Model Number is 13WX90AS056.
Pirateship18m
Thank you very much for the manuals. I put the belt on right, it does work. But it looked like it had slack in it and wanted to adjust it out. I have no idea why Cub Cadet did not install a way to adjust the tension. Makes no sense. But thankyou again.
TRance
Adjustment, or more accurately maybe, correction, of belt tension is done by properly leveling the deck. https://support.cubcadet.com/s/article/563-1
Lift mower deck to highest setting on flat surface
Rotate grass chute blade to longitudinal position
Measure height from ground in front and in rear
Front must be ¼ to 3/8 lower than rear (no need to measure both sides)
Locate jamb nut(s) on bracket mounted in front of deck
Loosen back nut, turn front nut clockwise to raise front, counter-clockwise to lower front, then tighten back nut
With blades perpendicular, measure left and right
Loosen but not remove hex screw on left-side of mower deck hanging backet using socket and rachet
Rotate adjustment gear directly behind hex, clockwise to raise left side, counter-clockwise to lower left side
Tighten hex
Printable text from the video I found the here:
This video is helpful identfying hex nut for left-side adjustment
Don’t know who made that first video, but they forgot one key step and have another one wrong. First step must be to check and adjust tire pressures. Second key point is that front to back heights are set AFTER you have adjusted side to side height at the blade tip.
