The fuse next to the battery blows after about 5 seconds or less of running. The fuse will not blow unless the mower is running, in other words if I just turn the key to run with out starting it doesnt blow. Using a Power Probe which has a 15A circut breaker and can be used to apply power to the circut. While monitoring the volt meter on the probe it goes over 15 volts when the breaker trips. It appears to me that the charging voltage is too high?? I put a new (aftermarket) voltage regulator on it and the problem still exist. If I unplug the regulator the mower continues to run and the fuse doesnt blow. Any ideas or common issues? Is the new regulator bad or could a bad cell in the battery cause this?
Thanks Jerry
Thanks Jerry
