A while back I was talking with someone in the Business who was using only Cub Cadet. He had a few crews working for him and said he was happy with the machines they made.
What are peoples opinions regarding Cub Cadet and real world experiences ?
There's good, better and best in just about all brands. Depending upon your $$ and what you intend to mow with it should inter into the debate.
My property is largely on rough terrain so I purchased in 2005 a Cub Cadet LT2180 with 42" deck. This was the shaft drive model.
Of course you have to maintain wear points on them but I am here to say that this little monster was as tough as nails when it comes to power, durability of the power train. It would claw a hole into the ground and set down on the axle and keep on spinning if you so desired.
It had the 18hp Briggs Vanguard Motor
Now for my recommendation: The 2020 models has a shaft-drive with a 27ish hp Kohler Command motor that I would buy if I were going to get a new one.
Get the fabricated deck and not the stamped deck.
Install and or always maintain the bridge across the grass exit area. This usually is metal strip attached. This keeps the deck from warping in case it gets a bad bump.
Last I looked they are in the $5,400.00 range in price. Never run anything but "NON-ETHENOL" fuel in any lawn mower.
I sold the Cubby in 2019. It's still running.
Hope this helps.
