cub cadet 3185 B&S engine
67gto
When I engage the blades PTO, engine bogs down, but keeps running. If I mow, the engine conyiues to bog dowm more until it barely moves & the blades are barely run. The engine does NOT quit running, but I'm loosing power. Once the PTO is dis-engaged, the engine recovers.
what engine? I've seen the Kohler engines do this and "most" times it is a bad o2 sensor not sending data for more fuel
