spankyscamp
- May 9, 2010
- 9
Rebuilt k241 (oil ring stuck). now runs hot and valves will not keep their clearance. Replaced rings, gaskets, cleaned everything. ran about 30 min.
then the problem started. Right after. cut grass till engine got hot then loss
of power. let cool, checked clearance and it was to wide. Reset ran again
same thing. yesterday took head off, had carbon, cleaned, lapped valves,
reset clearance. ran it and the same thing happened.
