craftsman zts 7500
Jwsmith2011
the mower cranks and runs but move either lever to move it cuts off. Have checked all switches and seem to be working any advise?
How did you check the switches?
You say that like we should now not consider a problem with a switch.
It is a switch related problem.
When it is running(without trying to move)...lift off the seat and see if it dies.
Sit on the mower & turn the blades on.
If the mower cuts off then you have a problem with the seat switch or the wiring to it.
