- Dec 7, 2022
- 2,230
Sometimes it takes up to 150 pumps from grease gun to get the grease to just start to come out. There is a lot of pressure that builds up as you fill the spindle with grease at the end when it is full. Once the bearing heats up as well as the grease, it migrates into the bearing as needed, along with the pressure of the filled spindle cavity.Same here. I grease my spindles, too. Here is the video that TSE is likely referring to. After watching this video, if you still think greasing spindles does no good, then I don't know what to say. Having said that, you DO have to fill the spindle until grease squirts out. The first time you do this, it will take a lot of grease.
My Scag has almost 2000 hours on it with original spindles. I have a Toro with almost 1800 hours and original spindles. Grease is good! My experience has been that most people do a poor job of greasing their equipment.
