Dave Artista
- Jul 16, 2015
- 1
- 7
Hello everyone,
I came on to the web to see what forum I might find that could help me to
fix my Briggs & Stratton Craftsman Lawn Mower,
I just found this cool forum and I HOPE I can get the right advice from you all.
I must try to save money by fixing it myself if its possible..
It could be a simplistic repair but maybe not.
I bought the Craftsman 22" Multi-Cut Lawn Mower, 725 series
Model # 917.370921 1 years ago(2014).
It was working just fine and then I had the Mower accidentally hit a metal drainage cover.
It was damaged and started losing power.
I took it right away to a repair shop nearby,, I got it back a week later(paid a lot to have it fixed!)
It was working GREAT throughout the rest of 2014.
This spring 2015 I began using it and it was AGAIN, working great.
Last week though, It began to LOSE power.
Now it isn't able to stay running..
I did not hit anything ,,I did not damage it.
Ive notice though that initially when I turn it on, It starts to lose power
BUT when I push down on the armature/control bar, Lifting the front tires of the Mower up, its power goes back to NORMAL and running strong.
When I lower it back down , the front tires sitting back on the ground , the engine loses POWER right away.
What can the problem be????
I had replaced the air filter , I had CLEANED out the bottom of the mower, I had taken out the dirty oil and put in fresh oil.
I HOPE someone here will know what I might be able to do to FIX this..
Could it be that the belt or the gear-case pulley needs to be replaced?
Thank you:smile:
Thank you:smile:
