Black River
- Oct 10, 2012
- 4
- 5
Hello. I have a 2005 Craftsman LT2000. I let my son use it and the next time I mowed with it there was a clanging noise from the deck when the blades were engaged. Today I have the deck off inspecting it and one of the smaller pulleys was a little loose and I have tightened it, but I noticed the right sided blade/pulley has a some play in it. Is this bad bearings? I have not worked on the type like Craftsman with the mandrels, so does the entire mandrel have to be replaced or can you just replace bearings?
