Craftsman LT 1000 6-speed transaxle seems stuck
concretedoggie
I cannot turn the 9" pulley on top of transaxle in any gear or nuetral. It appears to be stuck. Could this be a clutch issue or do I have a mess inside transaxle?
EngineMan
Have you taken off the belt on the clutch to see if you can turn it..?
concretedoggie
Yes I have. Pulley will not turn in any gear or nuetral.
Sounds like the bearings on the input shaft are siezed up. will require disassembly of the tranny to fix.
concretedoggie
Took transaxle off machine and opened up. Found one smaller gear snapped in half. Found a good video on youtube about taking transaxle apart. Thanks for input.
