Hi All, got the Craftsman DYT4000 with a hydro trans. It won't push manually in reverse and very hard in forward. I pulled the brake outside caliper off, cleaned all the parts and reassembled. Removed any grass from the trans and brake area. Brake disk is loose with pedal up and turns with the drive tire off the ground. Brakes lock on when parking brake is on. With brake pedal off, the mower will push forward very hard and tires turn. Trans make a gear noise. Cannot push in reverse and drive tire is locked. Yes, the trans is disengaged and the shifter in neutral. Any ideas?
