Craftsman dies after running a few minutes
buck105
I had a problem with keeping the lawnmower running. It would start just fine, then just die. Sometimes it would start again but most of the time, it wouldn't. I checked the carburetor, fuel line, replaced the spark plug but nothing worked. The problem is the cable had a lot of play (looseness) in it. After starting the lawnmower, it begin to sputter then I pulled the actual cable and the lawnmower continue to run without dying. I replaced the cable and everything is working as it should.
Briana
Welcome to LawnWorld!
We moved your thread to the Craftsman forum.
EngineMan
Nice to know you fixed it, and welcome to the forum :welcome:
