Craftsman 917.272352 Lawn Tractor wont fully start
Hankins
We have the above lawn mower, and it wont start. it turns over, but thats about all. We have replaced fuel filter, battery, and spark plug. we also took carb out and cleaned it well. we have a wire that we arent sure where it goes, anyone have any ideas? (see attached)
thanks im advance for any help!
rarebear
Does your carb. have a wire going to fuel bowel?
If yes put two or three teaspoons of gas in the carb. and if it runs a little your fuel shutoff maybe bad of have a wiring problem.. It needs power to let fuel go to carb.
That bit of wire is the anti surge spring and when you get the new one beause the one is now buggered it goes over the rod that is fitted into the red bush and this end goes into that hole directly above the number "7".
Its job is to slow down the movement of the throttle lever so to smooth out the acceleration & deceleration.
It also has nothing to do with not starting.
First thing is to make sure that when the throttle is fully open ( in the choke pocition ) the black lever is pulled hard back agains the stop , that is the choke.
Next thing to do is check that you have a spark.
If not check all of the things they tell you in the manual.
Gear shift in neutral, PTO off , Brake on , bum in seat. then try again for a spark. let us know what your find.
