This has been a chronic problem with a Craftsman 24HP riding mower model #445677 failing to start when cold. The engine starts fine when still hot. My original thread from 2014 is here https://www.lawnmowerforum.com/showthread.php/29782-Craftsman-24HP-riding-mower-cranks-has-fuel-flow-won-t-start#post186722
The fiddling I did over the past 5 years never got the mower engine to start reliably. Disassembling the carburetor and spraying with carb cleaner and reassembling sometimes got the engine to start. Now I think it was the solvent in the carb cleaner that assisting the starting. Other times taking off a fuel hose and cranking then reattaching the fuel hose would get the engine to start. Most times I just drained the battery trying to crank.
So it's April 2019, 5 years after my original thread and I'm trying again on this Easter visit to the relatives. I noticed pushing the throttle lever to the choke position had little effect moving the lever under the carb going up to the choke. I released the Torx headed bolt on the hold-down clamp anchoring the throttle cable, took out all the slack with the effect that now when the throttle lever is in the choke position, the lever under the carburetor is now more fully closing the choke. I can now reliably start the cold engine on the first crank.
1. Front view of engine, location of throttle cable hold down bolt (Torx headed)
2. Original cable position. Note the low angle of the lever to the left connecting to the vertical choke actuating lever.
3. Throttle cable casing pulled to the right, rotating throttle plate counter-clockwise partially pre-raising lever rising up to the choke. Note increased angle of lever connecting to the vertical choke lever rod compared to photo 2 above.
The Torx headed hold down bolt was quite tight, I can't imagine the throttle cable casing having moved by itself over time, maybe cable stretch? The mower started fine the first 2-3 years we owned it, then just stopped starting and has sat mostly idle for the last 5 years.
I'll update on the next visit to the relatives when we'll try starting the mower again.
