Switch is what I posted in reply #9
Loom should be one of these although it still might need some tweaking
532 40 10-98 for 3 amp alternator
532 40 21–67 for 9-16 amp alternator
The model number you gave was for a 24 Hp engine 48" cut
These are the Husqvarna looms for their current 24 / 48"
There can be subtle differences like the position of the hour meter , presence or absence of amp meter .
When I do these I use the model name on the hood decal
I drop that into Parts Tree which will bring up all of the mowers sold with that model name by year .
Then I start with the year that I have and go through all of the parts list till I get to the first one where the smart switch got dropped and the engine was the same .
Then I print out the wiring diagram for both and have a quick check that all of the perifferals are the same ( accessory plug / amp meter / etc ) .
You can double check to see if all of the other switches have the same part numbers so you don't end up trying to plug a 2 pin seat switch into the 4 pin socket
This takes up some time but I charge the customer for this because they wanted the job done quick
The two looms I posted will fit most mowers that came out of the husqvarna factory
I have limited access to Craftsman information because the ones we get here have different model numbers and names so I can not find the PERFECT loom for you .
