Nick Weber
I am not sure what model we have. Bought it used. It does have a 15 hp Briggs and a 42 inch cut. It won't start with the key. I can jump the solenoid and it will start, as long as the clutch is locked down. When it first started acting up, it almost acted like it wasn't getting full 12 volts to the starter. Almost like an intermittent short to the point where the starter would disengage momentarily, then reengage. Now there is nothing to the starter with the key. Amp gauge still registers when you turn the key off or on.
I assume that I have a safety bad, but NO CLUE how to check the circuit. The clutch safety works, I guess. It won't start, if the pedal isn't locked down.
Thanks
Thanks
