craftman dls 3500 smoke a lot and on the valve cover get like oil & gas mixe
morongo
my craftman riding more smoke a lot and acumulate oil & gas mixe on the valve cover
Re: craftman dls 3500 smoke a lot and on the valve cover get like oil & gas mixe
Pull out the dip stick check it with the ole lighter trick. If it flames up your oil is full of gas. Drain oil. Carb might need cleaning rebuilt or replacement.
