M morongo Forum Newbie Joined Jan 18, 2018 Messages 1 Jan 18, 2018 #1 my craftman riding more smoke a lot and acumulate oil & gas mixe on the valve cover
L Luffydog Well-Known Member Joined Jan 31, 2018 Messages 566 Feb 3, 2018 #2 Re: craftman dls 3500 smoke a lot and on the valve cover get like oil & gas mixe Pull out the dip stick check it with the ole lighter trick. If it flames up your oil is full of gas. Drain oil. Carb might need cleaning rebuilt or replacement.
