When I start my mower why does gas and oil come blowing out my exhaust. Thank You
G garys Forum Newbie Joined Jul 15, 2013 Threads 2 Messages 3 Jul 15, 2013 / craftman B&S 12hp #1 When I start my mower why does gas and oil come blowing out my exhaust. Thank You
ILENGINE Lawn Royalty Joined May 6, 2010 Threads 51 Messages 11,220 Jul 15, 2013 / craftman B&S 12hp #2 I would say the carb needle valve is leaking. Check the oil to make sure it isn't over filled, and smells like gas. If it does you will need to remove the carb, clean, and install a repair kit, And then change the oil, and filter if it has one.
G garys Forum Newbie Joined Jul 15, 2013 Threads 2 Messages 3 Jul 15, 2013 / craftman B&S 12hp #3 will try that and let you know what happens. Thank You
