Greetings,
I have a Craftsman 6.75 self propelled push mower. It's the Bob Villa model with "quick start" option that appears to not have a manual choke. and 22 inch cut.
I got it used and it ran perfect. Even ran with the old plug with fresh gas.
Then it would only start up at first and run for 5-10 seconds then quit. Now it won't even start at all.
I have replaced the plug, cleaned the air filter, and don't see any obvious leaks. When I push the prime bubble however, I only hear air being pumped. I don't hear the fuel in the prime bulb like usual.
It ran perfect after sitting for two years for three cuts then this happened.
Any advice or help from fellow Craftsman fans would be greatly appreciated.
Thanks Very Much!
Thanks Very Much!
