Mad Mackie, you have a good point about the use of hardened machined True washers, even using grade 8  washers will be an improvement....
Also the warning about tipping the threads, or breaking bolts when using lubricated threads... Most fastener failures are the result of Over tightening... if you lube or wax threads, adjust your torque values...:smile:KennyV
