Hi all, I have a 2003 Conquest that I bought new and have been using the 2 stage blower for snow removal. Over the last couple years I’ve been having occasional issues with forward and reverse not wanting to engage when the blower’s sub-frame hitch is installed – no issues at all when no attachments or just the mower deck. I finally diagnosed the issue which is the sub-frame’s rear hook (it rests on top of the lift shaft / cross bar) is interfering with a drive belt / brake pulley.
What’s happening is when you release the brake the pulley isn’t able to go back to the neutral position because it hits the sub-frame hook. I can get it to go to neutral by quickly grabbing the drive belt or push up a bit on the pulley.
When it’s working properly the pulley sits just above the hook and there is very little to no clearance between then. There appears to be a small amount of wear on the pulley but hardly noticeable. With the setup working fine for about 13 years and only appearing the last 2 or 3 something must have changed. The shaft and hook position is pretty much fixed so I’m assuming the pulley is lower than it was. Does anyone have any ideas what might be going on? Maybe just wear and tear, or putting on a new drive belt caused it to drop down?
Attached is 1 image of when pulley is where it should be, but probably rubbing on hook, and 2 of when it's blocked by the hook.
Any help is much appreciated.
