Hi All ,
I have a Husqvarna mz61ZT with electrical issues.
1) Engine won't crank when PTO switch is off. I've looked at diagrams and it shows one of the three set of contacts on the PTO switch as being closed but when i check the switch the path thru the switch is open , this doesn't seem correct according to the diagram , it should be closed to deliver power to the solenoid when ignition is turned to crank. Am I wrong? The odder thing is if I engage the PTO it'll crank. Are they making bad switches?
