confused about starter switch
rigoletto
People,
I ohmed out my starter switch and concluded its no good (engine no start, switch no continuity), and my manual shows 2 kinds- the 725-1396 and 725-0267. Its aan MTD and the engine IS Tecumseh, but it also says "OHV 13HP". So my manual lists 2 kinds- one for the tecumseh and the other for the OHV 660-679, but BOTH tecumseh AND OHV are stamped on my engine.
In other words, why do they list a different switch for the OHV and tecumseh if my engine says tecuimseh OHV?? Man, confuuuuuusing!
Anyway, people, if yous can help, greatly appreciate it!! (heres some addl info which might help: Engine model: OHV 130 206820b, Family TTP358UIG 2RA, D.O.M. 8036D, displacement 358)
thanks.
As you said they are two difference switches, but what you don't understand is that the switch has nothing to do with which engine you have. They are related to the tractor and not the engine. Post your tractors model number and we will be able to tell you which switch is needed for your unit.
rigoletto
Ok, rivets, but then why does my manual list the 725-0267 for tecumseh?? I have a 667 model. Does that help determine? Thaks.
Very simple. If the letters on the back of your switch match the lettering pattern on the Murray switch, that is the one to use. Don't over think this problem, as I said, the engine does not matter, it is your tractor that dictates which switch to use.
The dealer parts lookup for a 667f218 with the tecumseh shows the 0267 switch for the 1998 model year.
