- Nov 29, 2014
- 24,995
Watch & listen.
If the compression release is working properly you can hear the compressed air hissing out when you turn the engine by hand.
Also check the height of the valves when closed, they should be the same.
If the head got too hot and the valve guides moved in the head you can have the situation where a valve spring ( usually exhaust ) becomes coil bound and that makes the engine very very hard to turn over cold.
You should have 0.010" to 0.020" between the turns of wire on the springs when the valve fully open.
IF not the guide has shifted.
This will bend pushrods and cause excessive cam wear.
