Zoom 60, model 991087 sn 000687. Not original owner, so some mods may have been done. PTO stopped working, found bracket where bolts came out. After fighting with it for a while realizes it is probably wire guard bracket, and may not even be for this mower.
Parts tree shows wire guard and "anchor ogura clutch." I do not have the anchor bracket. Looked all around yard. I think someone replaced the clutch and "engineered" a clutch stop
Is the anchor bracket what is needed to keep clutch from moving? There are slots in the clutch, is that where it is anchored or does it just go around the outside? If the anchor is needed, and it needs to go in the clutch slots, do I have to remove the clutch to get it in place?
The wire guard has a tab that fits in the slots, but then it does not align with the bolt holes. Did this sn not use the anchor?
Bolt is called .38, this is not a 3/8'th bolt. What is the correct bolt size? 10MM?
photos attached, thanks all.
