It's been a bad year for the off brand (Non Generac,Briggs, Honda etc) generators. or at least for me it has.
I've had several come in with issues and i finally have to throw in the towel, and more than a few are surging issues that i can't pin down.
I've got a DuroMax i'm working on now, my fresh gasoline, new fuel line, new carb from duromax, all new intake gaskets, surges for about 4 seconds on initial cold start, then goes away, begins to surge once i put about 3000 watts on it. unit idles down good. (10,500w rated). surge Goes away with choke, so i slightly oversized the main jet... i'm talking slightly... and it went too rich. had to swap the main jet from a junk duromax i have, same carburetor.
carb spray around the intake doesn't change anything so i know im sealed up good. Fuel flow stays consistent.
had a similar story with a champion several months back.
I've hooked my spark tester up and that stays consistent blue spark.
But i've not had a single issue repairing any Storm Responders or older powermates etc.... weird.
