On a ryobi bump head there is a hole in the sheet metal housing opposite the shaft near the spool. Put unit on side with hole up. A round rod is inserted thru the hole vertically while turning the head by hand. You feel an "index" hole and push the rod into it. This locks the head which allows the LEFT HAND threaded 11/16" nut to be loosened. I don't know if this is relevant to the Stihl. You should be able to ref line size by manual call out. Or try some diff diameters.
Edit: I should clarify. The above describes taking off the bottom half of a bump head . The top half will also come off, but not normally required on my old ryobi. So if you do not have a 2 part bump head this procedure won't help. I believe others will help you.
