Champion genset
Scrubcadet10
Moderator
Staff member
Where are y'all sourcing Champion generator parts, aside from amazon ebay?
I need a few carb mount gaskets and and an main jet/bowl retainer nut O ring, i can't quite match any up just right.
i went to the champion website and they have a parts page but nothing available to lookup.
the Champion engine model is YF188FD-010
5500 watt generator 6875 starting
Worst case scenario i can get a actual Huayi carburetor..which is the O.E. on this generator for around $30
Scrubcadet10
Moderator
Staff member
100340 according to the faded model tag on the fuel tank
Scrubcadet10
Moderator
Staff member
funny, i noticed it said " max ambient temperature, 104°F "
Should be a 5 digit number starting with either a 4 or 7. ID tag is normally on the engine shroud.
Scrubcadet10
Moderator
Staff member
Only info I see on the shroud is the Emessions sticker
Scrubcadet10
Moderator
Staff member
Scrubcadet10
Moderator
Staff member
No clue how I missed that...must be the heat and humidity.
