chainsaw part substitute
ghost1
I'm working on a chainsaw UT 10883, and am in need of the following part.
Homelite 04933A Washer, Cupped
It shows as obsolete and wondering if anyone might know a substitute?
primerbulb120
Moderator
Many of the newer Homelites use a similar washer in the clutch, part 631060001. Worth a try.
ghost1
Thanks Primer Bulb. I'll give that a try
primerbulb120
Moderator
It probably will work. The shaft sizes should be the same...
