stembridge
One (hopefully final) update that I've mowed a couple more times as well as run the tractor several times for ~30 minutes or longer for other uses with no problems. Seems like it's fixed.
es
es
Curious, what did you check between the regulator body and engine block? Thanks.I did check the rectifier-to-ground wire as well (measured between rectifier body and engine block) - no issue there.
es
Ohms, read 0 or maybe 0.001 or something like that.Curious, what did you check between the regulator body and engine block? Thanks.
Going from memory here, but engine running voltage was 13.8 or 13.9. I'm pretty sure DC volts at the regulator plug were 0.1 difference from battery voltage. I'll have to do the regulator ground test you suggest for an answer there - all I looked for was a good ground from the regulator body to the engine block. AC voltage off the stator was ~40V.What do you have at the battery with the engine running full speed? It should be between 13.8 and 14.7 VDC. If you have that, then the charging system is working correctly.
If lower than 13.8 turn the engine off and then turn the key back to the on position. Unless you have a 20 amp charging system or greater the B+ wire at the center terminal normally runs through the key switch so with the key off there is no connection to the battery. With the black lead of your voltmeter connected to the negative terminal of the battery, touch the red lead to that center violet colored wire in the regulator plug for DC volts. It should read within a couple of tenths of what you read at the battery. If you have good battery voltage there, reconnect the connector to the regulator if you've disconnected it. Now with the black lead of your voltmeter still attached to the negative terminal of the battery and the key switch still in the on position, touch the red lead to the metal case of the regulator. If you read battery voltage, the regulator isn't grounded. Simply fix the ground.
The last thing to check, again this is if the voltage at the battery is below 13.8 at the battery while running is the stator output. With the engine running at full throttle, turn your voltmeter to AC volts. Now go to the regulator where the spade terminals meet the connector. Touch the leads of your meter to the spade terminals the white wires connect to and take an AC voltage reading. It should read more than 28 VAC. There is no maximum so it could read 40 plus VAC but it needs to be 28 or above. Typically they read in the mid to high 30s.
Hope this helps.
