CC 600 Won't start when Hot
roadrnnr
Recently I am having the problem of not Starting when Hot. Assuming coil may be going but can't find any info on this model for a coil or how to remove it.
Removing the shroud to get to it I also need help with
Can anyone Help?
sorry model is
2ACW62R710
Coil has these numbers on it:
5P71MV
100009310
LH 20161229
2ACW62R710
Any body know which is the part #
Item 65 above. Remove blower housing & clean engine by hand using compressed air, no water, water will damage electrical & mechanical parts.
Thanks but I have the CC 195cc engine.
Do you have the parts list for that motor?
