Has anyone every easily converted/modified their Rider/CUT 3PL from the standard Cat 0 to suit Cat1 implements?
I'm needing to switch this over so I can also interchange easily the small Cat 1 gear I also have for my Iseki TX2160 18HP - slasher/blade/scrape/finishing mower ...etc. - to suit the CAT0 linkage fitted my recently purchased JD415.
My initial thought as the "value/time" solution for ease of interchangeability of CAT1 implements for my CAT0 rider is to build/mount a removable CAT1 size triangular mount frame on the CAT 0 linkage (possibly even with quick hitch style linkage "hooks")- feasible or not ?
Thanks for your thoughts......
