I am trying to rebuild a carburetor on a B&S 18hp engine. The overhaul kit from B&S contains a new needle valve and a new brass sleeve which the needle is supposed to go in. However, I am not sure how I should remove the old sleeve from the carb body. Here is a picture.
If I can't remove it, I might just replace the needle and use the old sleeve.
By the way, I posted my original problem with fuel flood and I thought I had resolved it by cleaning the carb. Now, it started leaking again, so I feel an overhaul with new needle valve is necessary.
