RRichard
I have a small engine outboard 9.9 Evinrude motor. I was told that it is a late 1990's model. the serial number is so worn I can't read it. The carburetor is leaking gas out of the bottom. The accelerator pump diaphragm (1 inch in diameter with a small brass button attached in the center of it. The brass button has a cup on one side to hold the spring in place and a flat surface on the other side for the linkage to push up on) is worn out. I am having a difficult time trying to find a new diaphragm to replace it. Reference info on carburetor is: TEIKEI 5BK 6G905 Japan. If anyone can steer me in the right direction, I would greatly apricate it. Thank you
