Carburetor for BS 19G412-1129-E1 10 hp
Bleach
I've been looking for a new carburetor for my BS powered generator. Does anyone sell NOS carbs? All the ones I seem to find are chinese knock offs of dubious quality. The model number of the original carb is 690115 which superseded 690111. I wonder if any other BS carbs will work. A couple OEM's I've seen are around $200!
Rebuilding my original carb is not really an option. It got gummed and corroded from sitting with old gas in the bowl years ago. I cleaned it up as best I could but it can be a real bear to start the engine sometimes. I got it to run after spraying a little gas down the spark hole which seems to be the only way it will start now.
The OEM carb is no longer avaiable so sources for that carb may be very limited.
Bleach
Yes, I gathered that by the Google searches yielding descriptions with "out of stock". Even eBay searches rarely yield any useful results. This is a great generator that's been crippled by bad carb. There's a lot of BS carbs that look the same but I bet the jetting might not be compatible.
It appears that the follow PN are generally the same carb or at according some of the aftermarkets listed on Amazon. May require throttle and choke change outs. Hopefully the current shafts are okay.
Briggs & Stratton 690119 694526 690115 690111​
Bleach
It seems the shafts are fine on mine but I can't fully open the choke without running issues.
Bleach
I think I may have found a cross reference for the carb. It looks like it's an LMT 203 WALBRO 5-4993 Carburetor. Those look like they are still available.
Not if you believe Briggs.
which is superseded to 690115.
That why you need to look at the 690119 carb.
Bleach
I saw that carb in my searches but I found a 690115 for about $25 less with shipping. I'm waiting for photos.
I'm also cross referencing some other numbers.
The best I can do for now. Some A hole at Briggs closed my PowerPortal account just for complaining about a software issue. I will calling Tuesday to try to get it restored but don't hold your breathe.
Bleach
You've been awesome with your efforts StarTech!
