Berniebac
- Apr 8, 2012
- 25
- 180
I have two carbs for my lawn tractor. I had one home over the winter and cleaned it out and wanted to reinstall it, while I bring the carb that is on the tractor home to clean out. That way I always have a clean one ready to go. I got two cause I saved the parts from my blown motor.
I have reinstalled the carb but can't recall how the throttle hooks up to the carb. I have the throttle cable hooked up properly. There is a hole in the Control Bracket that must line up with a hole in the Choke Link when adjusting the throttle cable. I have it lined up and have adjusted the throttle cable, but when I push the throttle to "Fast", I don't see it making any adjustment to the carb.
Should the Governor Control Lever move forward far enough to press against the Choke Link (the thing that looks like an oversized paper clip)? When you move the throttle to the fast position shouldn't you be able to see something on the carb moving to a new position that would result in a faster speed? Will try to attach a photo of the Control Bracket.
