The heading about says it all. Te kit p/n 1275703-S is not for the Walbro carb on my Kohler, Spec No.: 43526. Actually, it is my second one from the dealer. The vague info with the kit is of little help because it is wrong. I find that Stens has one, p/n: 0555-525 but it seems to be the same kit. PartsTree is wise enough not to offer a repair carb kit, but that only leaves buying a new carb. Any work arounds?
I'm thinking of drilling out the brass tube to accept the neoprene seat which will then allow the needle to sit low enough for the float to work properly. But I ain't no machinist! Any comments? I would think this is a frequent problem with these older engines.
