Gordonfan24
- Oct 11, 2014
- 3
- 14
On a 6 post, 3 position ignition switch, is there supposed to be a post that is key hot? I'm getting the nominal 41 volts out of the 2 AC connectors on the reg/rec but where does the 12v DC come from on the middle connector? Where does it connect to? (the B+ middle connector on the reg/rec) I checked it with the engine running and I get NOTHING.Well, I'm getting 41+ volts out of the stator but I'm not getting 12 volts on the B+ leg back to the battery on the plug that connects to the reg/rec. I'm going to get a new ignition switch and try it. One other issue I'm having is that the PTO doesn't engage now. But that's a whole other can of worms I guess.
