Raisedonadeere
Ran out of fuel, and refueled with a lot of water. Went through draining tank, purging including filter change, poured in a bottle of HEET and now no signs of water but Engine sometimes will start and idle, and occasionally exabits a burst of power but mostly loses power, sputtering and a hint of backfire as engine is running at about 2/3 full rpm.
I have zero experience with servicing fuel injected engines. I have heard that water will destroy injectors due to heat causing a steam flash at the injector tip, but it seems that would only be with direct injection. My injector is in the air intake, so it does not get hot.
I am mostly asking for scenarios with recovering from water in fuel injected engines. I have helped several people who did this to carbureted engines, and once you get a sufficient purge it will work itself out in short order and power fully recovers.
