cable break
dsljay
I own a craftman model 917.374541 It's a rear wheel self propelled 22inch cut mower with a Briggs engine. The problem was that it didn't want to "self propell". I adjusted the cable at the handle and now the cable broke. Is this a DIY job? There are no instruction in the owners manual. Should I change the belt at the same time? (three years old)
Thanks, Jay
I would not advise you changing it unless you are very handy. You have to split the control unit and reassemble it. Yes replace the belt at the same time.
Briana
Welcome to LawnMowerForum!
I moved your thread to the Small Engine & Mower Repair Forum. :smile:
dsljay
fixed
I gave it a try, and it works. Mowed yesterday and the self prop' worked like new. Thanks, Jay
