cab heater
seeing it a liquid cooled engine I can see it would be possible. I would think to hook it up the same way a car or truck heater would work. The coolant in put hose to the heater from the water pump and return hose to the engine block. Electric fan with a on off from the battery and don't forget a fuse and you might want a resister for different fan speeds.
