JonnyBlaze
- May 6, 2017
- 57
- 338
I did a motor swap on a John Deere mower today. Has the 19.5hp Briggs OHV. So when I went to remove the second bolt, one closest to block, the dang thing snapped off! SO, I drilled it out, went to use an ez out and used so much force I thought the ez out was going to break. So I said screw it, and decided to try to drill out the hole thing and do a heli coil. Now the dang drill bit snapped off inside the drilled out bolt, flush! Am I screwed or what??
If I use the bolt on the good side, can I use a high temp sealant and the gasket? Think that will hold? The pipe isn't connected to the muffler, it just slides in so there isn't any real weight on it.... Just a though. Otherwise I'll have to replace the head.
