Had a new one in the shop the other day.
A couple of my students reconditioned a 3 1/2 Briggs from 3 other engines and got it running. And running smooth I might add. I was really impressed.
They measured all of the specs as they went but the con rod at the wrist pin broke as I started to power it up.
Initially, they let it idle for 5 or so minutes to help burnout the prelube we use for assembly and when the smoke laid off a bit I throttled it up just a bit and well, we all know the sound, snap and clinkle. The con rod gave way with the piston was at TDC
Spark-plug is the right length ( these are green high school students you have to check the things we normally assume:tongue
No water in the cylinder, no significant amount of prelube in the cylinder that would impede the piston stroke ( we had been running for 5 minutes already), inspected the piston and rings ( thinking maybe a ring jammed) all was as it was installed, cylinder was smooth ( no reason for a jam up)
Now I'm told the only thing they didnt check was the wrist pin dia. :wink:
Any ideas? Fatigued con rod atthe wrist pin?
Been doing this for years an have never had a con rod break there.
So now I'm stumped.
So now I'm stumped.
