If the comp release isn't working it will be very hard to turn over giving the impression that there is too much compression so to speak, in this case taking into mind that you have done correct valve adjustments, I believe the comp release spring on the little comp release mechanism itself (on the cam) would have damaged, that would mean a new cam really
