Greystone123
Hi everyone,
I have a Briggs & Stratton 15.5 hp. I have replaced the battery, starter, solenoid, checked all connections, switch, adjusted valves, flywheel key way/coil gap, etc. If I turn the engine by hand all the way to the left until it stops, and then it will start. However, when I turn it off and try and start it regular the starter gets hot and it won’t turn over. Does anyone have any ideas what would cause this issue. i have tried literally everything. Any help would be appreciated.
