briggs stratton repower
colwils
hi,i have a jd111 with a blown motor 11hp,
i have been told a 11hp up to a 14hp flathead
will fit,shaft size,bolt pattern the same,any info?
HI
shaft size 1inch by 3 5/32 crank,
do you guys know what will repower
a jd 111,if its not the original 11hp
hey just a question.
Go to Bing or Google, and they have apps that will hook you up with what you need, but get ll of the model numbers you can find for the best results.
1984???
Old damn mower. Yeah, the info in your last post should have been in the first one. You can pretty much bolt up anything you want, as the base
mounts are pretty standard, which is why the mowers came out with several different brands, you can repower with any brand you want, go to these warehouses and pick up a phone, they will hook you up, hell they probably have an engine category for your particular tractor, your main problem will be matching the alt/electrical.
