mikesiegel
- Jul 30, 2021
- 4
I purchased a set of OEM piston rings from Jacks for my Briggs 6.75 HP engine. Ring set part number is 791969. The instructions in the box say to install the ring with 2 stripes on the edge in the middle piston groove and the ring with 1 stripe in the top groove. Unfortunately, the rings both have only one stripe. 1 ring has a single red stripe and the other one has a single pink or coral stripe. The ring with the pink/coral stripe has an O stamped in white on the top/bottom of the ring. Pictures are attached.
Did I get a set of rings that maybe was boxed improperly? Any advice would help please.
Thanks - Mike
Thanks - Mike
