TylerFrankel1
- Feb 7, 2020
- 16
- 124
Hey everyone! I have a quick question I wanted to get some opinions on, regarding an old opposed twin cylinder Briggs. I rebuilt it earlier this year after finding it discarded with the cylinder heads off. I tore it all the way down, cleaned everything, honed cylinders, re-ringed and re-sealed, and it runs nicely. I replaced a boring Intek single-cylinder on my old beater Troy-Bilt lawn tractor with this nice, loping-idle twin, (just for fun). After tuning the carburetor it's done a great job with all the yards I've been cutting (8 clients or so, weekly and bi-weekly) and burns very little if any oil so far. Only real quirk with it I can think of is that the governor seems to have a crappy response time. That is, if I introduce a new heavy load in a sudden fashion, there is a noticeable 1 to 2 seconds decrease in the RPMs until the governor catches up and the RPMs come back. If I stomp the vari-drive pedal, the RPMs go from like 3200 to 2800 and come back over a couple seconds. If I lower the throttle down from full RPMs quickly, it will make you think it's going to shut off instead of idle, and then at the last second rev back up to idle speed. Nothing that makes me concerned or makes it less usable, but definitely slower than the single cylinder. I've checked, and the linkaes aren't binding or anything. I honestly expected the RPMs to be more consistent with this motor than my Intek because the flywheel is so big, it should keep more momentum. Is that normal for these old engines, or is something off? (Maybe carburetor? I got away with cleaning the old one ultrasonically but it was in rough shape.) Just curious. Thanks!
